Digital frequency change after transmit
Posted: Fri Nov 29, 2024 3:33 pm
I have a problem when using WSJT-X that when I transmit, say I am between 500-1000 Hz on 10 m (28.074 MHz) and the software will tell the radio to transmit at 28.073 like it should but when it unkeys, it stays at 28.073. This happens on any band.
I have a beam antenna up 8m above the shack and transmit usually with 40~50 watts. I have changed patch cords, adapters, grounded from everyway possible with a 1:1 balun also on the coax. This only happens on 10m. The antenna and SWR reading at the radio is 1.1:1. I am currently using firmware 2.2.2, ID OrionMKII, Protocol 2 (v3.9) I have had other stations get online to observe my transmitted signal to make sure it was clean and have been assured it is.
I have also noted that, if I decide to stop the transmission utilizing the halt button in WSJT-X, when it is transmitting at say 28.073, when it unkeys, it stays at 28.073 and not back to the receive frequency of 28.074.
Is this a software problem? CAT? I'm all ears for ideas.
John
KC4LZN
John
KC4LZN
