SpotCollector Spots to Panadapter
Posted: Sat Feb 15, 2025 9:33 pm
by Ric-W5IHL
Is there a way to send spots from DXLab's SpotCollector to the Thetis panadapter?
Current cofig allows a click on a spot in SpotCollector to change Thetis frequency.
Tnx everybody! Rik
Re: SpotCollector Spots to Panadapter
Posted: Sun Feb 16, 2025 2:56 pm
AFAIK there is currently no way to do this. The spots-in-panadapter feature only works with the built-in spot client.
Posted: Sun Feb 16, 2025 4:09 pm
by NC3Z
Is there a specific reason you need to use SpotCollectors spots?
4 ways I use or have used is via TCI using:
Current way -
https://www.oe3ide.com/cluster-tci-bridge/Previous ways -
https://www.lw-sdc.com/ or
https://www.log4om.com/ or
https://www.swisslogforwindows.com/
Posted: Sun Feb 16, 2025 8:26 pm
by w9ac
Gary,
Thanks for the suggestion. The setup screen was very intuitive; I had it up and running in about five minutes, including the web server.
Posted: Sun Feb 16, 2025 11:37 pm
by Ric-W5IHL
Thank Scott. Are you still using the DXLabs suite?
Posted: Sun Feb 16, 2025 11:43 pm
I am, but I don't use SpotCollector. I'm not a DX chaser.
Posted: Mon Feb 17, 2025 1:06 am
by Ric-W5IHL
Gary, I'm currently using TCI-Bridge but since I use DXLab, I wanted to compare SpotCollector to TCI-Bridge.
Yes to SDC too and I run it on occasion but have found it to be tricky and poorly documented.
I'm surprised SpotCollector can't send spots to other clients. Maybe I'm mistaken but does it not support the Flex panadpter?
73s Rik
Posted: Mon Feb 17, 2025 1:22 am
by NC3Z
Ric-W5IHL wrote:I'm surprised SpotCollector can't send spots to other clients. Maybe I'm mistaken but does it not support the Flex panadpter?
SC doesnt work with Flex either, I use either SDC or FRStacks3 for that.
