Hello around
Still no movement
OK, small information. I found cheapest encoders on Aliexpress, 2x times than on Farnell. Look here: [url]
https://www.aliexpress.com/item/33052809089.html[/url]
Small hint, choose AliExpress Standard Shipping and you will get it fast
There are just a slight problem, knobs... There are not knobs for 3.5mm shaft
I didn't find. Possible part:
http://www.leobodnar.com/shop/index.php?main_page=product_info&cPath=98_75&products_id=197Just smaller shaft are 4mm, but that isn't a big deal, use some tape or whatever. Lars 3D printed knobs are nice, but even on best possible quality, you can see layers. I printed one
There are one expensive part DB9 connector, 17USD from BOM. I check for cheaper, L77SDEH09SOL2RM5 and A132506-ND in Digikey. Like a 10X cheaper. If there are any disadvantages of using these parts, let me know
I didn't check it yet, there are obsolete parts, LEDs. I will check it later.
Most expensive part are front panel, any idea how to get cheaper? Group buy, cheaper manufacturer
But group buy would end with similar price, because of postage.
And finally case
It is possible to buy different cases on Ali. Just cases are cheap, but postage are
And it will definitely met with custom, for EU. Even more price. And I didn't find required size.
Let's move this swamp
