SpotCollector Spots to Panadapter
Ric-W5IHL
Postby Ric-W5IHL » Sat Feb 15, 2025 9:33 pm
Is there a way to send spots from DXLab's SpotCollector to the Thetis panadapter?
Current cofig allows a click on a spot in SpotCollector to change Thetis frequency.
Tnx everybody! Rik
7000dle Blue Face
FW: v2.1.18
Thetis v2.10.x...x64
Win10
Re: SpotCollector Spots to Panadapter
Postby w-u-2-o » Sun Feb 16, 2025 2:56 pm
AFAIK there is currently no way to do this. The spots-in-panadapter feature only works with the built-in spot client.
NC3Z
Postby NC3Z » Sun Feb 16, 2025 4:09 pm
Is there a specific reason you need to use SpotCollectors spots?
4 ways I use or have used is via TCI using:
Current way - https://www.oe3ide.com/cluster-tci-bridge/
Previous ways - https://www.lw-sdc.com/ or https://www.log4om.com/ or https://www.swisslogforwindows.com/
w9ac
Postby w9ac » Sun Feb 16, 2025 8:26 pm
Gary,
Thanks for the suggestion. The setup screen was very intuitive; I had it up and running in about five minutes, including the web server.
Ric-W5IHL
Postby Ric-W5IHL » Sun Feb 16, 2025 11:37 pm
Thank Scott. Are you still using the DXLabs suite?
7000dle Blue Face
FW: v2.1.18
Win10
Postby w-u-2-o » Sun Feb 16, 2025 11:43 pm
I am, but I don't use SpotCollector. I'm not a DX chaser.
Ric-W5IHL
Postby Ric-W5IHL » Mon Feb 17, 2025 1:06 am
Gary, I'm currently using TCI-Bridge but since I use DXLab, I wanted to compare SpotCollector to TCI-Bridge.
Yes to SDC too and I run it on occasion but have found it to be tricky and poorly documented.
I'm surprised SpotCollector can't send spots to other clients. Maybe I'm mistaken but does it not support the Flex panadpter?
73s Rik
7000dle Blue Face
FW: v2.1.18
Win10
NC3Z
Postby NC3Z » Mon Feb 17, 2025 1:22 am
Ric-W5IHL wrote:I'm surprised SpotCollector can't send spots to other clients. Maybe I'm mistaken but does it not support the Flex panadpter?
SC doesnt work with Flex either, I use either SDC or FRStacks3 for that.
