Arduino sketch for PowerSDR cat
erict35
Postby erict35 » Tue Apr 18, 2017 4:19 pm
I have seen some arduino libraries for FlexRadio.
I’m looking for a simple Arduino sketch that interpret the “ZZFA” and “ZZFB” result strings to make a band decoder for my homebrew amplifier (input filter).
My future TX is the Anan8000 with PowerSDR and I don’t want to use de TTL signals on the J16 port but the serial data on the PoweSDR cat serial port.
Do you know where I can find this code ?
Bests 73s
Eric – F1FLY
F5AFV
Re: Arduino sketch for PowerSDR cat
Postby F5AFV » Thu Jan 17, 2019 8:06 am
Bonjour
Avez vous résolu votre probléme de CAT
entre ANAN 8000 et ARDUINO
73's Pierre F5AFV
f5afv-p@wanadoo.fr
Postby w-u-2-o » Thu Jan 17, 2019 12:00 pm
dj1yr
Postby dj1yr » Fri Jan 18, 2019 4:01 am
Hi Alex,
read better the Alexbus, the Orion MK2 board outputs 48bit, LPF, BPF1, BPF2, you read the last 16bit, that is the information for antenna / lpf including TX Signal.
regards René
