Database not saving TX EQ Enabled and Phase Rotator Endable options
KW4CQ_Bob
Postby KW4CQ_Bob » Fri Nov 08, 2019 1:11 am
After clicking on the Transmit Equalizer (enable) and the Phase Rotator (enable) and then on Apply and then saving the changes to a new database by clicking on OK, when I Import that same database all saved settings I made are there except that the two enabled options I just described are not saved. They are unchecked. I have to re-enable those two every time. Any thoughts on this?
Bob KW4CQ
Re: Database not saving TX EQ Enabled and Phase Rotator Endable options
Postby Tony EI7BMB » Fri Nov 08, 2019 9:26 am
Try saving as a transmit profile Bob if you have not done so already.
KW4CQ_Bob
Postby KW4CQ_Bob » Sat Nov 09, 2019 2:22 am
Thanks Tony. That works.
73 Bob
Return to “PowerSDR mRX”
