This may be in the wrong forum, if it is please move it to the correct forum:
I have a close friend that has the 7000 DLE, the problem he's having is when trying to change frequency and typing the frequency in the space, only two numbers appear when he only typed one number but it repeats that number and that's as far as it will let him go.
I don't have an answer for him so I'm here hoping someone can help with this problem, maybe there's something he changed in the setting he's not aware of.
Can't type in a Frequency
Re: Can't type in a Frequency
I have an 8000 DLE and had the same issue using PowerSDR.
I've since changed to the Protocol 2 firmware and using Thetis where that issue has been corrected.
Its well worth the change and replacing the firmware is fairly straightforward if you follow the instructions.
Best of luck
Best of luck
All the best
Nigel
VK6CPU
INTEL i9 12900 64.0 GB Ram
Nigel
VK6CPU
What version of PowerSDR mRX is your friend running? Direct frequency entry was a problem with version 3.4.8 but it was quickly corrected with the follow-up release of the 3.4.9 version. I have not experienced this or heard of it being a problem with v3.4.9.
